    How to set main controller in PCSX2
    GamePad/GPIO/USB encoder
    main pcsx2
    7
    • TheWhite
      TheWhite last edited by
      Hi,
      The controller assignment works in Libretro PCSX2 but not for PCSX2 standalone which has much better performance. Is there away to set which controller is primary in PCSX2 standalone.
      It always wants to use the Dragonrise controller board instead of the PS4 controller thanks.
      Also PPSSPP always want to use the PS4 controller instead of the dragonrise controller which works well with the arcade controls.
      TheWhite 1 Reply Last reply Reply Quote 0
      • TheWhite
        TheWhite @TheWhite last edited by
        @thewhite I have tried in the controller config in the PCSX2 menu but it does not stay at the highlighted controller once restarted.
        Cyberien 1 Reply Last reply Reply Quote 0
        • Cyberien
          Cyberien last edited by
          Salut !
          Je serai également intéressé par une solution si elle existe !
          Merci d'avance et encore bravo pour tout ce que vous faites
          • Cyberien
            Cyberien @TheWhite last edited by
            @thewhite Je viens d'essayer ça et ça à l'air de fonctionner :
            edit le fichier PAD dans share/system/.config/PCSX2
            Efface les configurations des autres pad et ne laisse que ton controleur principal.
