    Problem with the Monitor Dell 2707 WFPc
    monitor dell 2707 wfpc
    • Pampersjoe
      Pampersjoe last edited by
      Hello together,
      i m new here my Name is Mike 😃 and i build my own Arcade. I m happy with it but it does not work 😞
      What is exactly my Problem:
      I use a raspberry pi with the original power supply! I got some controllers. The Monitor is an old DELL 2707 WFPc (27"). I have to convert from HDMI to DVI. The Monitor has an resolution 1920x1080 @ 60 Hz.
      The recalbox starts fine... sound and video looks good but.... if i want to start "any" rom, it doesnt matter which one, the recalbox starts the normal black screen with the PAC-Man Ghosts and after this... it will return to the ROM-Lists like this person here:
      https://www.youtube.com/watch?v=R8xrsoRM_a0
      What did i tried...
      In the recalbox-user-config.txt i changed:
      hdmi_group=1 (as i understood for CEA)
      hdmi_mode=16
      next try
      hdmi_group=2 (as i understood for DMT)
      hdmi_mode=82
      in this group the monitor will not start! So i change it back to the defaults and tried to change settings in the recalboxconfig (global.videomode with the same settings (=CEA 16 HDMI) but the problem still exists.
      Pls... what am i doing wrong?
      If i do this: tail -F logs/*
      the only thing i can see is:
      ==> logs/es_log.txt <==
      [2022/05/18 11:24:41.699] (INFO ) : [Run] Launching game...
      [2022/05/18 11:24:41.700] (INFO ) : [Input] Configure emulators command :  -p1index 2 -p1guid        03000000b50700001203000010010000 -p1name "Mega World USB Game Controllers" -p1nbaxes 4 -p1nb        hats 1 -p1nbbuttons 12 -p1devicepath /dev/input/event3 -p2index 0 -p2guid 0300000014030000280        3000010010000 -p2name "D_R_M JUYAO Dual Arcade" -p2nbaxes 4 -p2nbhats 1 -p2nbbuttons 14 -p2de        vicepath /dev/input/event1 -p3index 1 -p3guid 03000000140300002803000010010000 -p3name "D_R_M        JUYAO Dual Arcade" -p3nbaxes 4 -p3nbhats 1 -p3nbbuttons 14 -p3devicepath /dev/input/event2
      [2022/05/18 11:24:41.700] (INFO ) : [Run] Controllers config :  -p1index 2 -p1guid 03000000b5        0700001203000010010000 -p1name "Mega World USB Game Controllers" -p1nbaxes 4 -p1nbhats 1 -p1n        bbuttons 12 -p1devicepath /dev/input/event3 -p2index 0 -p2guid 030000001403000028030000100100        00 -p2name "D_R_M JUYAO Dual Arcade" -p2nbaxes 4 -p2nbhats 1 -p2nbbuttons 14 -p2devicepath /d        ev/input/event1 -p3index 1 -p3guid 03000000140300002803000010010000 -p3name "D_R_M JUYAO Dual        Arcade" -p3nbaxes 4 -p3nbhats 1 -p3nbbuttons 14 -p3devicepath /dev/input/event2
      [2022/05/18 11:24:41.700] (INFO ) : [AudioManager] Shutting down SDL AUDIO
      [2022/05/18 11:24:41.899] (INFO ) : [Run] Command: python /usr/bin/emulatorlauncher.pyc  -p1i        ndex 2 -p1guid 03000000b50700001203000010010000 -p1name "Mega World USB Game Controllers" -p1        nbaxes 4 -p1nbhats 1 -p1nbbuttons 12 -p1devicepath /dev/input/event3 -p2index 0 -p2guid 03000        000140300002803000010010000 -p2name "D_R_M JUYAO Dual Arcade" -p2nbaxes 4 -p2nbhats 1 -p2nbbu        ttons 14 -p2devicepath /dev/input/event1 -p3index 1 -p3guid 03000000140300002803000010010000        -p3name "D_R_M JUYAO Dual Arcade" -p3nbaxes 4 -p3nbhats 1 -p3nbbuttons 14 -p3devicepath /dev/        input/event2 -system snes -rom /recalbox/share/roms/snes/3\ Ninjas\ Kick\ Back.zip -emulator        libretro -core snes9x2010 -ratio auto
      [2022/05/18 11:24:41.901] (INFO ) : [Pad2Keyboard] No pad2keyb configuration.
      [2022/05/18 11:24:41.902] (INFO ) : [Hardware] Start in-game Hardware processes
      [2022/05/18 11:24:41.902] (INFO ) : [MQTT] Publishing to tcp://127.0.0.1:1883 from recalbox-e        mulationstation OK!
      [2022/05/18 11:24:43.137] (INFO ) : [Hardware] Stop in-game Hardware processes
      [2022/05/18 11:24:43.138] (WARN!) : [Run] Non-Zero exit code 1 !
      [2022/05/18 11:24:43.138] (INFO ) : [MQTT] Publishing to tcp://127.0.0.1:1883 from recalbox-e ```
      If i took an other Monitor (BenQ 24xxx) directly with HDMI and the same resolution it works fine out of the box with the same setup/hardware!!!
      Could someone help me in this case?
      Thx
      • Alvin
        Alvin Banned @Pampersjoe last edited by
        @pampersjoe
        Did you try this ?
        https://wiki.recalbox.com/en/tutorials/video/lcd/dvi-screen
        Pampersjoe 1 Reply Last reply Reply Quote 0
        • Pampersjoe
          Pampersjoe @Alvin last edited by
          @alvin It was default with #
          What i tried to do is hdmi_drivers=1 which i found here:
          https://elinux.org/RPiconfig#Video_mode_options
          1 = DVI (no Sound)
          But also no luck.
          • Alvin
            Alvin Banned @Pampersjoe last edited by Alvin
            @pampersjoe said in Problem with the Monitor Dell 2707 WFPc:
            Did you do it right ?
            It's not "drivers"
            it's
            hdmi_drive=1 Normal DVI mode (No sound)
            Nur zur Info für den Threadersteller:
            Ich schreib' dann in deinem deutschen Thread weiter wenn mir noch was einfallen sollte:
