    "Share" partition on SD card
    share partition
    • joe-berndt
      joe-berndt last edited by
      Since v4.0.0, my "share" partition no longer appears as a drive.   I'm using a micro SD card reader and a Macbook Pro.   "RECOVERY" and "BOOT" partitions still show up.   Can anyone tell me how to get the "SHARE" partition back? (I am sometimes in a location that doesn't have wifi so I can't always just SSH in)
      • nosfay
        nosfay last edited by
        Hi, You may try to use Paragon ExtFS for MAC, I personally use ext2fsd for Windows, both are adding a driver that allow you to see EXT partition. Recalbox v3.2 was on FAT32 format, and 4.0 is on ext4 if I'm not wrong.
