    Recalbox8 all emulators are not working
    recalbox8 are
    • heiner
      heiner last edited by
      Hello,
      I updated to the newest release and at first I could play everything but the next day the controller (Shawan PS3) did not connect again and every emulator gives and error message that either the ROM or the BIOS is corrupted.
      I did a clean install but the problem persists.
      Any ideas?
      regards,
      heiner
      Alvin 1 Reply Last reply Reply Quote -1
      • Alvin
        Alvin Banned @heiner last edited by Alvin
        @heiner
        Maybe you should tell us on which System (Raspberry Pi (which on ?), PC, Odroid or something else) you're running Recalbox.
        If you use a Raspberry Pi maybe you should try another SD-Card.
        heiner 1 Reply Last reply Reply Quote 0
        • heiner
          heiner @Alvin last edited by
          @alvin
          I use a raspberry pie 3 (B?)
          • Alvin
            @heiner said in Recalbox8 all emulators are not working:
            @alvin
            Maybe your SD-Card is broken, try another one.
            If the Problem than occurs again it's a Problem with Recalbox.
            101.4k
