    building pc with 2 drives
    Your recalbox
    building drives
    • thecaver99
      thecaver99 last edited by
      Hi.
      I'm putting together a tiny pc as a recalbox system but looking to have the os boot from the m.2 128gb hdd and all my roms on an internal 1tb 2.5" hdd, is this possible to do or does everything need to be on the same drive.
      • Alvin
        Alvin Banned @thecaver99 last edited by
        @thecaver99
        This should be possible
        The HDD's must be connect to the Motherboard in the Way that the 128 GB HDD is Drive C and the 1TB HDD is Drive D.
        1. Disconnect your 1TB HD from your Motherboard (only to be sure that Recalbox is installed on the right HDD)
        2. Install Recalbox on your 128 GB HDD
        3. Shut down your PC, connect your 1 TB HDD (be sure it is formatted with the exFAT Filesystem) and then start Recalbox again.
        4. In the Main Menu go to SYSTEM SETTINGS -> STORAGE DEVICE
          Your 1 TB HDD should be listed here.
          Select it and let Recalbox reboot.
          You can read the Rest here
          https://wiki.recalbox.com/en/tutorials/system/installation/usb-device-as-storage
          under "Configure Recalbox to use a USB storage device"
        You don't have to worry because it's describe how you use an USB Stick or an external HDD, it should work with an internal HDD too.
        And you don't have to synchronize your HDD.
