    Amiga CD32
    Emulator Arcade/PC/Console
    amiga cd32
    1834
    • salvo
      salvo last edited by
      Dear all,
      I have an issue with Amiga CD32 Roms, noone is working, the Roms' format is ok and the Bios are all in the folder, can you help me, please?
      Thanks
      Regards
      • Alvin
        Alvin Banned @salvo last edited by
        @salvo
        Maybe wrong BIOS ?
        In Recalbox 8 there's an Option in the Main Menu to check if the BIOS is OK.
        Look here:
        https://wiki.recalbox.com/en/basic-usage/features/bios-manager
        Or check the MD5-Checksum of the BIOS here
        https://wiki.recalbox.com/en/emulators/consoles/amiga-cd32/amiberry
        salvo 1 Reply Last reply Reply Quote 0
        • salvo
          salvo @Alvin last edited by
          @alvin Hi dear, I've checked the Bios thanks to the feature on Recalbox, it is the one I used as reference to find all the Bios I have in, the Bios for this platform are indicated as ok.
          Regrads
          • Alvin
            @salvo
            Did you try all 3 Amiga CD 32 Emulators ?
            Amiberry
            Libretro PUAE
            Libretro UAE4ARM
            • salvo
              @alvin Hi dear, I think I did it but I will double check to be sure. Thanks
              Regards
              • salvo
                salvo @salvo last edited by
                @salvo Hey dear, I lost one piece of your first reply, you said me to check not just the Bios but even the system compatibility which I didn't make, I'm running Recalbox on a Windos Laptop and if I've seen well from the link you sent me this is not compatible, can you confirm the emulator will not work on Windows based laptops?
                Thanks
                Regards
                • Alvin
                  @salvo
                  Well, here it says at last the
                  Libretro PUAE Enulator
                  https://wiki.recalbox.com/en/emulators/consoles/amiga-cd32/libretro-puae
                  should be working on a PC
                  The other two
                  Amiberry
                  and
                  Libretro UAE4ARM
                  https://wiki.recalbox.com/en/emulators/consoles/amiga-cd32/libretro-uae4arm
                  not
                  salvo 2 Replies Last reply Reply Quote 0
                  • salvo
                    @alvin
                    I will try then, thanks.
                    BR
                    • salvo
                      @alvin
                      I have just that Emulator at the end, I cannot see other emulators available, it goes to the CD running screen, the CD runs and runs and nothing happens and if I click on X it goes to a screen with a locker and even there nothing happens.
                      Regards
