    Dolphin settings to play Wii games
    Emulator Arcade/PC/Console
    gamecube tabs
    • Akharecal
      Akharecal last edited by Akharecal
      Hi,
      I use an Intel NUC (mini-PC), the Mayflash Dolphin bar and 2 genuine Wii remotes (forget clones, I've tried many, not working with Recalbox in my case).
      Plug a wireless keyboard and mouse before powering on Recalbox.
      Launch a Wii game.
      Use Alt+F4 to stop the game and access Dolphin emulator menu.
      This is the minimum configuration and should work for many (but with a loss in graphics):
      In Configuration->Wii,Gamecube tabs, define your language for Wii and/or Gamecube games.
      In Configuration->Audio tab, enable adapt audio to emulation.
      In Graphics, change resolution to 2x (720p).
      In Graphics, disable shaders (Asynchronous, Skip drawing).
      Close dolphin (select+start on my 8BitDo). Restart a Wii game and again Alt+F4. Verify the modified settings are still there.
      If you have more power, try a game after changing one by one this settings in Graphics :
      • enable shaders (Synchronous)
      • change resolution to 3x (1080p)
      • antialiasing to 2x
      You could modify others settings but I try to keep it simple.
      Best.
      Paulska 1 Reply Last reply Reply Quote 0
      • Paulska
        Paulska @Akharecal last edited by
        @akharecal
        from what ive read before, dolphin configuration resets itself after a restart.
        can you confirm the settings stick?
