    GPi CASE 2 - CM4 with internal eMMC + SD-card
    gpi case cm4 internal emmc sd-card
    • jone12121
      jone12121 last edited by
      Hi,
      I installed recalbox 8.02 on internal eMMC (16GB) memory. This works fine. Now I want to use an SD card (128GB) for roms. The SD card is not mounted automatically. How can I mount the SD card?
      fdisk -l
      Disk /dev/mmcblk0: 15 GB, 15634268160 bytes, 30535680 sectors
      477120 cylinders, 4 heads, 16 sectors/track
      Units: sectors of 1 * 512 = 512 bytes
      Device Boot StartCHS EndCHS StartLBA EndLBA Sectors Size Id Type
      /dev/mmcblk0p1 0,32,33 392,99,27 2048 6303743 6301696 3077M c Win95 FAT32 (LBA)
      /dev/mmcblk0p2 392,131,60 1023,254,63 6305792 28436480 22130689 10.5G 7 HPFS/NTFS
      /dev/mmcblk0p3 1023,254,63 1023,254,63 28438528 30535679 2097152 1024M 83 Linux
      Only one Memory (internal eMMC) shows up. Why?
      Thanks
      • jone12121
        Is it possible that the SD card slot does not work when using a Raspberry Pi Compute Module 4 with eMMC?
        • danbee
          danbee last edited by
          Sadly you cannot have both. The eMMC CM4's do not have the SD card wired up at all.
          • meepmeep
            meepmeep last edited by
            Meaning it will never be possible to use eMMC + SD on a gpi case2?
            • meepmeep
              Official information :
              If you look at the official CM4 IO board from the Raspberry Foundation, it says right on the board that micro SD card cannot be used with eMMC CM4s
              So .. I have an useless CM4/4G/16Gb mmc/W+B 😄
