    Can't access Chorus2 web interface
    MediaCenter & Dualboot
    cant chorus2 web interface
    • grumblesnake
      grumblesnake last edited by
      I'm still very new to Recalbox, so I might just be missing something, but can't seem to access the chorus2 web interface in my browser, as I instead just get an option between the different control options, nor am I able to control it through the Kore app on my android phone, though that might have something to do with no option to "Allow remote control via HTTP" .
      Previously I had kodi and retropi installed on Raspberry pi OS on my RP4 and it worked perfectly.
      Does Recalbox Manager replace the Chorus web interface?
      Recalbox seems like everything I want from my system and would be sad to revert to the old system, so any help would be much appreciated.
      Regards
      Simon
      grumblesnake 1 Reply Last reply Reply Quote 1
      • grumblesnake
        grumblesnake @grumblesnake last edited by
        @grumblesnake
        I've tried to disable the Recalbox manager, hoping that would give the chorus web interface priority, but that only means going directly to /index.html?analog when I try to access the chorus web interface.
        I then tried to make it boot directly to kodi, but that seems to make the system hang on boot with the ES progress bar filling and emptying unendingly. Reflashing seems to be the only solution to that.
        grumblesnake 1 Reply Last reply Reply Quote 0
        • grumblesnake
          @grumblesnake
          I figured it out. I guess you have to use the port 8081 instead of 8080.
          So if anyone reads this, the address for the kodi web interface is: [ip-address]:8081
          Is this really common knowledge? Otherwise I think it should be stated somewhere on the website or in the manager.
          I found it out by searching the forum a bit more thoroughly and came up with a comment mentioning a now non-existing github link.
          Regards
          Simon
