    CRT-Pi on Raspberry Pi 4
    crt-pi
    • Madmeggo
      Madmeggo last edited by
      Hi all
      I'm running the latest Version (8.0) on a Raspberry Pi 4 and noticed that my favourite shader, namely crt-pi doesn't work anymore. I checked the forum and found a thread with a suggested fix:
      Downloading shaders.tar.xz from /share_int/, unzipping it and moving all files to /share/shaders/
      Well I did that and the crt-pi shader still doesn't work. All files are complete and where they belong. I restarted the system and also tried it on a completely fresh system. No luck.
      Is there anything I can do or does someone know what's the problem with the shader?
      I really would like to use the shader again 😞
      • olivierdroid92
        olivierdroid92 Global moderator @Madmeggo last edited by
        @madmeggo hello
        You are right.
        On pi4 this issue is known.
        It's solved . Ref https://gitlab.com/recalbox/recalbox/-/issues/2065
        It will be release in the next coming 8.0.1
        Madmeggo 1 Reply Last reply Reply Quote 0
        • Madmeggo
          Madmeggo @olivierdroid92 last edited by
          @olivierdroid92 thanks for the info. Glad to hear that this will be fixed in a future release 🙂
