    Baby steps
    Your recalbox
    baby steps
    • netterdan1
      netterdan1 last edited by
      I'm having difficulty getting Recalbox to install properly, so I thought I'd go back to basics.
      1. Does card size/type matter? I have a Geeekpi 32Gb Class 10 MicroSD card.
      2. Does format matter? Fat32 or ntfs?
      3. Should I give the card a specific name before I flash to it?
      I can't find this info anywhere. Thanks in advance.
        Zing Global moderator Translator @netterdan1 last edited by
        @netterdan1
        Yes, we recommend a class 10, 16gb sandisk Sd card. It works with other brands and sizes, but it needs to be at least class 10 to avoid slowing down. Ideally, use SD card only for system, and external storage device to store ROMS/BIOS/etc/etc...
        Yes, we recommend exfat (but FAT32 works too, we recommend avoiding NTFS).
        No. After flashing, you need to do the first boot, and at that moment the system will create the other partitions, wait for the first boot until the end.
        I recommend that you read the wiki:
        • https://wiki.recalbox.com/en/home
        Watch the video tutorials from the official youtube channel (enable the subtitles):
        • https://www.youtube.com/playlist?list=PL2oNQ0AT7fx2ExiSNrfHUzga5GnogI4sh
        And if you like it, use our official Discord:
        • https://discord.com/invite/NbQFbGM
