    Problems with default roms
    Emulator Arcade/PC/Console
    default roms
    2163
    • Alex.Murphy
      Alex.Murphy last edited by
      Hi all,
      i enjoyed recalbox few years ago and it worked like a charm.
      Few days ago i decided to reactivate my raspberry pi, for that i installed the latest recalbox version 8.0. After that i was really suprised that even most of the default roms that comes with the default image are not running.
      Examples:
      • GameBoy / Retroid
      • SNES / Unwol Quest for Money
      • Atari 7800 / Meteor Shower
      My Specs:
      • Raspberry PI 3B
      • Recalbox 8.0 (official image from https://www.recalbox.com/download/stable/rpi/rpi3/)
      Error (appears after starting a game):
      Any ideas if there's something wrong with the standard image?
      Regards,
      Alex
      • sharky
        sharky last edited by sharky
        Hi,
        Can you check the BIOS?
        Start (for menu at home page) -> check Bios
        Perhaps there is something missing?
          Scavy Global moderator @Alex.Murphy last edited by
          Hello @alex-murphy
          Several possibilities :
          • a bios is missing : check the bios list (a missing bios file is updated in the bios folder).
          • you should look for better roms : for roms dumped from cartridges, choose a "no-intro" romset, for roms dumped from cd/dvd, choose a "redump" romset.
          Don't hesitate if you have further questions.
          Paulska 1 Reply Last reply Reply Quote 0
          • Paulska
            Paulska @Scavy last edited by
            @scavy he mentioned that the provided roms dont work.
            Im guessing something with the install process went screwy.
            i would redownload the image, and extract it first before burning again. see if that helps. then start the system, let it finish the whole process. try the default games then.
            unless you are trying to flash this to a ssd/usb. thats a different bag of worms.
              Scavy Global moderator @Paulska last edited by
              @paulska yeap, you're right thanx 🙂
              @Alex-Murphy if when reinstalling the problem persists, you should consider trying with an other sd card.
              • Alex.Murphy
                Alex.Murphy last edited by Alex.Murphy
                Thanks for your replies guys. I tried another SD Card, downloaded the image again, extract it before burning but nothing helps. Luckily a friend of mine has a raspi 3B as well and he had still the recalbox 4.0 on it. I made a image of his sd card and burned it on my sd card, and what to say, it works like a charm. Lessons learned, next time i wanna try a new version, i make a backup of the old one first 🙂
