    Dolphin Blue
    Emulator Arcade/PC/Console
    dolphin blue
    • neo207
      neo207 last edited by
      anyone tried Dolphin Blue on recalbox? i cannot manage to play the game. doesnt work on mame/fb neo... anyone can help or is it impossible at the moment?
      • roro21
        roro21 last edited by
        You have to put the rom (from the good mame romset version) in the "atomiswave" folder.
        There is also a version/adaptation for dreamcast .
        neo207 1 Reply Last reply Reply Quote 0
        • neo207
          neo207 @roro21 last edited by
          @roro21 thank you i will try that.
          • djsmo
            djsmo last edited by djsmo
            The Game looks great, but i have the same Problem. No Rom works with Mame on my Pi3.
              Scavy Global moderator @djsmo last edited by
              Hello @djsmo
              you have to check a good romset with the right core.
              Check the arcade documentation.
              https://wiki.recalbox.com/en/home
