    I'd like to about Overlay for PC x86
    Themes & Interface
    overlay x86
    • Infiltraitor
      Infiltraitor last edited by
      Hello guys,
      I was wondering if anyone had overlays working on emulators for recalbox running under PC x86?
      I was searching the forum all I have was for retropie not even on PC.
      I'd like to add that I'm using the 1:1 ratio or the pixel perfect on all emulators on a 1080 monitor.
      It would be nice to see even as simple as a CRT TV screen with retro library as background. And editable if possible.
        Zing Global moderator Translator @Infiltraitor last edited by
        @infiltraitor For Overlays, for now, use:
        https://forum.recalbox.com/topic/22321/recalbox-7-2-x-overlays-complets
        As you can read, one of the recommended options is to use ARRM to make configuration easier:
        https://forum.recalbox.com/topic/11850/soft-arrm-another-recalbox-roms-manager
        On the ARRM Wiki there is a warning:
        Do not activate the pixel perfect
        http://www.jujuvincebros.fr/wiki/arrm/doku.php?id=bezels_en
        I recommend that you test with ARRM, read the wiki, and, in case of problems, contact the developer at the corresponding topic.
        Infiltraitor 1 Reply Last reply Reply Quote 0
        • Infiltraitor
          Infiltraitor @Zing last edited by
          @zing Thanks Zing, the ARRM has overwhelmed me enough to think if its even worth setting an overly.
          May I ask are you using overlays? My system is a 2007 running x86 Recalbox. I am also thinking if it will impact performance more than the emulation.
            @infiltraitor
            I don't use it, although I think it's nice, I prefer to only display the game on the screen, and in a few cases it affects emulation (however rare), I prefer to avoid it.
