    Troubleshooting Ipega PG-9157 LE Bluetooth Gamepad
    GamePad/GPIO/USB encoder
    troubleshooting ipega pg-9157 bluetooth gamepad
    • primo
      primo last edited by
      I'm aware that they are already several topics concerning Ipega gamepads, and even tutorials, however the advice given doesn't seem to apply in this situation, as the approriate /dev/input/event nodes aren't being created.
      The gamepad connects immediately, and works without issue in both Windows 10 and Android 7. Moreover, it also works flawlessly in Raspbian, on the very same hardware, without any configuration whatsoever.
      Setup
      • Raspberry Pi 4 Model B 8GB
      • Recalbox 7.2.2-reloaded
      • Controller: Ipega PG-9157 Ninja
      Within Recalbox, the device connects are pairs successfully, however in the configuration menu it reports that no gamepads are detected. Inspecting the device in bluetoothctl shows that it is in fact not paired, but can be easily enough with the pair command.
      Afterwards, the result is this:
      [PG-9157]# info 03:21:04:15:94:27
      Device 03:21:04:15:94:27 (public)
              Alias: PG-9157
              Appearance: 0x03c3
              Icon: input-gaming
              Paired: yes
              Trusted: yes
              Blocked: no
              Connected: yes
              WakeAllowed: yes
              LegacyPairing: no
              UUID: Generic Access Profile    (00001800-0000-1000-8000-00805f9b34fb)
              UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb)
              UUID: Device Information        (0000180a-0000-1000-8000-00805f9b34fb)
              UUID: Human Interface Device    (00001812-0000-1000-8000-00805f9b34fb)
              UUID: Vendor specific           (91680001-1111-6666-8888-0123456789ab)
              UUID: Vendor specific           (f000ffc0-0451-4000-b000-000000000000)
              Modalias: bluetooth:v1949p0402d0000
      However, evtest shows nothing:
      # evtest
      No device specified, trying to scan all of /dev/input/event*
      Available devices:
      /dev/input/event0:      vc4
      /dev/input/event1:      vc4
      Select the device event number [0-1]:
      Inspecting /dev shows that no device nodes are created at all, not even so much as an hidraw. Despite this, the device does appear to be working, just not as a game pad. Whenever a button is pressed or released, data is sent which is easily discernable as a controller state, as viewed in btmon:
      Base state:
      > ACL Data RX: Handle 64 flags 0x02 dlen 17
            ATT: Handle Value Notification (0x1b) len 12
              Handle: 0x0026
                Data: 80808080ff0000000067
      "A" button pressed:
              Handle: 0x0026
                Data: 80808080ff0100000067
      Complete log of a reconnect is below:
      # btmon
      Bluetooth monitor ver 5.55
      = Note: Linux version 5.10.13-v7l (armv7l)
      = Note: Bluetooth subsystem version 2.22
      = New Index: B8:27:EB:70:13:B0 (Primary,UART,hci0)
      = Open Index: B8:27:EB:70:13:B0
      = Index Info: B8:27:EB:70:13:B0 (Cypress Semiconductor)
      @ MGMT Open: bluetoothd (privileged) version 1.18
      > HCI Event: LE Meta Event (0x3e) plen 32
            LE Advertising Report (0x02)
              Num reports: 1
              Event type: Connectable undirected - ADV_IND (0x00)
              Address type: Public (0x00)
              Address: 03:21:04:15:94:27 (OUI 03-21-04)
              Data length: 20
              Flags: 0x06
                LE General Discoverable Mode
                BR/EDR Not Supported
              16-bit Service UUIDs (complete): 1 entry
                Human Interface Device (0x1812)
              Appearance: Joystick (0x03c3)
              Name (complete): PG-9157
              RSSI: -67 dBm (0xbd)
      < HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2
              Scanning: Disabled (0x00)
              Filter duplicates: Disabled (0x00)
      > HCI Event: Command Complete (0x0e) plen 4
            LE Set Scan Enable (0x08|0x000c) ncmd 1
              Status: Success (0x00)
      < HCI Command: LE Create Connection (0x08|0x000d) plen 25
              Scan interval: 60.000 msec (0x0060)
              Scan window: 60.000 msec (0x0060)
              Filter policy: White list is not used (0x00)
              Peer address type: Public (0x00)
              Peer address: 03:21:04:15:94:27 (OUI 03-21-04)
              Own address type: Public (0x00)
              Min connection interval: 15.00 msec (0x000c)
              Max connection interval: 15.00 msec (0x000c)
              Connection latency: 0 (0x0000)
              Supervision timeout: 2000 msec (0x00c8)
              Min connection length: 0.000 msec (0x0000)
              Max connection length: 0.000 msec (0x0000)
      > HCI Event: Command Status (0x0f) plen 4
            LE Create Connection (0x08|0x000d) ncmd 1
      > HCI Event: LE Meta Event (0x3e) plen 19
            LE Connection Complete (0x01)
              Handle: 64
              Role: Master (0x00)
              Connection interval: 15.00 msec (0x000c)
              Master clock accuracy: 0x00
      @ MGMT Event: Device Connected (0x000b) plen 33
              LE Address: 03:21:04:15:94:27 (OUI 03-21-04)
              Flags: 0x00000000
              Data length: 20
              Flags: 0x06
      < HCI Command: LE Read Remote Used Features (0x08|0x0016) plen 2
              Handle: 64
            LE Read Remote Used Features (0x08|0x0016) ncmd 1
      > HCI Event: Command Complete (0x0e) plen 14
              00 00 00 00 00 00 00 00 00 00
      > HCI Event: LE Meta Event (0x3e) plen 12
            LE Read Remote Used Features (0x04)
              Handle: 64
              Features: 0x3d 0x00 0x00 0x00 0x00 0x00 0x00 0x00
                LE Encryption
                Extended Reject Indication
                Slave-initiated Features Exchange
                LE Ping
                LE Data Packet Length Extension
      = bluetoothd: src/service.c:service_accept() input-hog profile accept failed for 03:21:04:15:94:27
      < ACL Data TX: Handle 64 flags 0x00 dlen 7
            ATT: Exchange MTU Request (0x02) len 2
              Client RX MTU: 517
      > ACL Data RX: Handle 64 flags 0x02 dlen 7
            ATT: Exchange MTU Response (0x03) len 2
              Server RX MTU: 131
            ATT: Read Request (0x0a) len 2
              Handle: 0x000f
      > HCI Event: Number of Completed Packets (0x13) plen 5
              Num handles: 1
              Handle: 64
              Count: 2
      > ACL Data RX: Handle 64 flags 0x02 dlen 12
            ATT: Read Response (0x0b) len 7
              Value: 01491902040000
              Handle: 0x0003
              Value: 50472d39313537
              Handle: 0x0005
              Num handles: 1
              Handle: 64
              Count: 2
            ATT: Read Response (0x0b) len 2
              Value: c303
      < ACL Data TX: Handle 64 flags 0x00 dlen 11
            ATT: Read By Type Request (0x08) len 6
              Handle range: 0x0001-0xffff
              Attribute type: Unknown (0x2b3a)
      > ACL Data RX: Handle 64 flags 0x02 dlen 9
            ATT: Error Response (0x01) len 4
              Handle: 0x0001
              Error: Attribute Not Found (0x0a)
            ATT: Read By Group Type Request (0x10) len 6
              Attribute group type: Primary Service (0x2800)
              Num handles: 1
              Handle: 64
              Count: 2
      > ACL Data RX: Handle 64 flags 0x02 dlen 24
            ATT: Read By Group Type Response (0x11) len 19
              Attribute data length: 6
              Attribute group list: 3 entries
              Handle range: 0x0001-0x0007
              UUID: Generic Access Profile (0x1800)
              Handle range: 0x0008-0x0008
              UUID: Generic Attribute Profile (0x1801)
              Handle range: 0x0009-0x000f
              UUID: Device Information (0x180a)
              Handle range: 0x0010-0xffff
      > ACL Data RX: Handle 64 flags 0x02 dlen 26
            ATT: Read By Group Type Response (0x11) len 21
              Attribute data length: 20
              Attribute group list: 1 entry
              Handle range: 0x0010-0x0015
              Handle range: 0x0016-0xffff
              Num handles: 1
              Handle: 64
              Count: 2
            ATT: Read By Group Type Response (0x11) len 7
              Handle range: 0x0016-0x0028
              UUID: Human Interface Device (0x1812)
              Handle range: 0x0029-0xffff
              Handle range: 0x0029-0x0031
              Handle range: 0x0032-0xffff
              Num handles: 1
              Handle: 64
              Count: 2
              Handle: 0x0032
      > ACL Data RX: Handle 64 flags 0x02 dlen 6
            SMP: Security Request (0x0b) len 1
              Authentication requirement: Bonding, No MITM, Legacy, No Keypresses (0x01)
      > ACL Data RX: Handle 64 flags 0x02 dlen 16
            LE L2CAP: Connection Parameter Update Request (0x12) ident 114 len 8
              Min interval: 12
              Max interval: 12
              Slave latency: 0
              Timeout multiplier: 200
      @ MGMT Event: New Connection Parameter (0x001c) plen 16
              Store hint: Reserved (0x27)
              LE Address: 01:03:21:04:15:94 (OUI 01-03-21)
              Min connection interval: 12
              Max connection interval: 12
      < ACL Data TX: Handle 64 flags 0x00 dlen 10
            LE L2CAP: Connection Parameter Update Response (0x13) ident 114 len 2
              Result: Connection Parameters accepted (0x0000)
      < HCI Command: LE Connection Update (0x08|0x0013) plen 14
              Handle: 64
            LE Connection Update (0x08|0x0013) ncmd 1
      > HCI Event: LE Meta Event (0x3e) plen 10
            LE Connection Update Complete (0x03)
              Handle: 64
              Num handles: 1
              Handle: 64
              Count: 1
      What stands out most is line 87, and again line 194:
      = bluetoothd: src/service.c:service_accept() input-hog profile accept failed for 03:21:04:15:94:27. Grepping the internet for this error returns a number of results, with the following possible resolution:
      • Ensure that the kernel is compiled with CONFIG_UHID=y
      The only line generated in dmesg appars to be
      [  162.631750] Bluetooth: hci0: security requested but not available
      Whereas on Raspbian we see the following:
      [   61.335639] input: PG-9157 Keyboard as /devices/virtual/misc/uhid/0005:1949:0402.0004/input/input7
      [   61.338929] input: PG-9157 Consumer Control as /devices/virtual/misc/uhid/0005:1949:0402.0004/input/input8
      [   61.339373] input: PG-9157 as /devices/virtual/misc/uhid/0005:1949:0402.0004/input/input9
      [   61.350670] hid-generic 0005:1949:0402.0004: input,hidraw3: BLUETOOTH HID v0.00 Keyboard [PG-9157] on AA:AA:AA:AA:AA:AA
      It does appear to be using uhid.
      Is there are particular reason why this kernel module isn't included with Recalbox? Does a version exist (perhaps older version) which has it?
      • primo
        I resolved the issue by adding uhid to /etc/modules.conf, so that it is loaded at system start.
