    How do I delete the roms inside share_init?
    delete roms inside shareinit
    • Cereal-Killa
      Cereal-Killa last edited by
      After updating there are few unwanted roms from amiga, c64, etc inside share_init/roms and that dir is read-only.
      What's the easiest way of getting rid of these roms that came with the update?
      Thank you
        Scavy Global moderator @Cereal-Killa last edited by
        @cereal-killa hello,
        you can hide pre-installed games in the menu option.
        Cereal-Killa 1 Reply Last reply Reply Quote 0
        • Cereal-Killa
          Cereal-Killa @Scavy last edited by
          @scavy said in How do I delete the roms inside share_init?:
          Awesome, that was easy enough 😅
          Thank you!
