    MAME added rom do not load.
    Emulator Arcade/PC/Console
    mame added rom load
    • Jazzmaster76
      Jazzmaster76 last edited by
      Hello,
      Thank you in advance. i just bought this console with pre loaded games. I want to add some that are favorites and missing. Some worked and others did not. The screen goes black and just goes back to the start menu.
      They do work on my PC where i run a MAME32 0.103 version. What are my options here? Is there anything that i can do?
      Thank you.
      Scavy 1 Reply Last reply Reply Quote -2
        Scavy Global moderator @Jazzmaster76 last edited by
        Hello @jazzmaster76
        said in MAME added rom do not load.:
        Recalbox is totally free and can not be sold. I advise you to contact your reseller to get a support.
        Regards.
        Jazzmaster76 1 Reply Last reply Reply Quote 0
        • Jazzmaster76
          Jazzmaster76 @Scavy last edited by
          @scavy Thank you. What they are actually selling is the bartop with the controls and everything. Havent had much luck with their support really... If anyone could help me to run these two games i would be grateful The games are Exerion and WWF Superstars.
          Thanks again.
            @jazzmaster76
            Here is the arcade doc. In french for the moment, translators are on the way.
            You can use an online translator to help : https://recalbox.gitbook.io/documentation/v/francais/emulateurs/arcade
            • Jazzmaster76
              Thank you! I ll have a look see if i can find the answer to this 🙂
