    Expland fba2x.cfg
    expland fba2x.cfg
    • dh04000
      dh04000 last edited by
      Hello, since piFBA2 does not expose the mame config menu, is it possible for the fba2x.cfg file to be expanded with all the options found in the mame config available so users that want to make custom arcade controls can do so. I'd like access to setting my own fast forward, pause, volume up and down, and other such functions. These new functions could be left commented out in the file so the current function of the file would not be changed.   Thank you for your consideration.
        If you want all these functions use FBA_libretro core.
        • dh04000
          Rockaddicted -> If you want all these functions use FBA_libretro core. I have a RPi2, so isn't that version of FBA slow? I thought that was the reason that piFBA was included? Also, I have put a TON of effort in cleaning up my mame 0.78 and piFBA rom list to just the games I want to play and scraping by hand. Can I use the commands found in this below link to add to my own fba2x.cfg and get those extra functions myself? http://easyemu.mameworld.info/mameguide/mameguide-controlini.htm   Fore example, if I were to add   UI_PAUSE=112 #p   Then would piFBA pause when I hit the p-key on my keyboard?   EDIT: seems like any changes won't stick.
            nope pifba is included to be used on rpi1/0. fba_libretro run pretty well on rpi2.
            • dh04000
              rockaddicted -> nope pifba is included to be used on rpi1/0. fba_libretro run pretty well on rpi2. Oh, I had no idea..... well I wasted my time...... time to get new roms.... again..... What mame rom set version is recalbox 4.0 fba_libretro? EDIT: found it libretro-fba 0.2.97.37
