    [Recalbox 7.2.x] Hyperion Frame Grabber (Rpi4)
    [recalbox 7.2.x] hyperion frame grabber rpi4
    • tuxfamily
      tuxfamily last edited by
      Hello.
      Même soucis que sur ce post mais comme il est marqué "solved" alors qu'il ne l'est pas, je me permet d'en ré-ouvrir un... avec un peu + d'éléments ceci dit 🙂
      Pour ma part, j'ai un (vrai) LightPack USB (donc rien à voir avec le SPI), sur un Rpi4 avec Recalbox 7.2.2 fresh install.
      L'arc en ciel apparait bien et ensuite rien.
      En lançant directement hyperion avec:
      /etc/init.d/S25hyperion stop
      hyperiond /recalbox/share/system/configs/hyperion/hyperion.config.json
      on a des logs et on voit que le soucis vient (apparement) du "frame grabber"
      Hyperion Ambilight Deamon (1117)
      	Version   : (HEAD detached at 2d0d97e3b8) (digitalLumberjack-3b779a3ded/2d0d97e3b8-1623945268
      	Build Time: Jun 17 2021 22:08:22
      INFO: Selected configuration file: /recalbox/share/system/configs/hyperion/hyperion.config.json
      HYPERION INFO: ColorTransform 'default' => [0; 29]
      HYPERION INFO: ColorCorrection 'default' => [0; 29]
      HYPERION INFO: ColorAdjustment 'default' => [0; 29]
      LEDDEVICE INFO: configuration:
      	"colorOrder" : "rgb",
      	"name" : "MyHyperionConfig",
      	"output" : "XXXXXX",
      	"type" : "lightpack"
      USB context initialized
      Found a lightpack device. Retrieving more information...
      Lightpack device found: bus=1 address=3 serial=XXXXXX
      Lightpack device successfully opened
      Lightpack device opened: bus=1 address=3 serial=XXXXXX version=6.5
      INFO: Creating linear smoothing
      HYPERION (CS) INFO: Created linear-smoothing(interval_ms=50;settlingTime_ms=200;updateDelay=0
      EFFECTENGINE INFO: 27 effects loaded from directory /usr/share/hyperion/effects
      EFFECTENGINE INFO: Initializing Python interpreter
      INFO: Hyperion started and initialised
      INFO: Boot sequence 'Rainbow swirl fast' EFFECTENGINE INFO: run effect Rainbow swirl fast on channel 0
      BLACKBORDER INFO: threshold set to 0 (0)
      BLACKBORDER INFO: mode:default
      started
      INFO: Json server created and started on port 19444
      INFO: Proto server created and started on port 19445
      QtHttpServer started on port 31168 "Qt Static HTTP File Server"
      DISPMANXGRABBER INFO: Display opened with resolution: 4x1053479356
      INFO: Frame grabber created and started
      DISPMANXGRABBER ERROR: Snapshot failed: -1
      BORDER SWITCH REQUIRED!!
      CURRENT BORDER TYPE: unknown=0 hor.size=0 vert.size=0
      On y voit 2 erreurs:
      et
      A partir de là j'ai regardé si on pouvait spécifier un autre type de "grabber" pour recalbox mais je n'ai rien trouvé 😞
      En tout cas ça ne semble pas être lié au matériel / au light pack lui même.
      Est-ce que quelqu'un aurait un "hyperion.config.json" qui fonctionne sur la même config (Rpi4/7.2.X) ?
      Merchi.
      Zing stratagem 2 Replies Last reply Reply Quote 0
        Zing Global moderator Translator @tuxfamily last edited by
        @tuxfamily Voyez si cela vous aide :
        https://recalbox.gitbook.io/documentation/v/francais/tutoriels/autres/hyperion-sur-recalbox
        • stratagem
          stratagem @tuxfamily last edited by
          @tuxfamily mon soucis a été reglé. J'ai posté le détail ici: https://forum.recalbox.com/topic/24282/recalbox-7-2-x-hyperion
          En espérant que ca fonctionne avec Lightpack USB.
          Raspberry pi4B/RB v7.2.1/manettes dragonrise/borne arcade/hyperion
