    Display Issue since update to 7.2.1
    Your recalbox
    display issue since update 7.2.1
    • afsztt
      afsztt last edited by
      Hi, since updating to 7.2.1 reloaded, the main menu does not display to the correct ratio any longer, for example the menu options at the bottom are slightly off the screen. And when I load the games from MAME the top part with high scores is not displayed and neither is the bottom part with credits. All was displayed fine on the previous version. How do I fix this? Can I roll back to the previous version?
      Thanks,
      Allan
        Scavy Global moderator @afsztt last edited by
        Hi @afsztt
        Could you please describe your configuration ? (PC CPU/GPU, Pi3, Pi4, Odroid ?).
        https://forum.recalbox.com/category/46/important-read-me-first
        Before posting section.
        Thanx 🙂
