    8bitdo SN30Pro+ buttons don't respond when paired.
    GamePad/GPIO/USB encoder
    8bitdo sn30pro+
    • ebonwinds
      ebonwinds last edited by
      Hi
      I'm using an 8bitdo SN30 pro +. The firmware is up to date and I am able to pair it with the current version of Recalbox (7.2 Reloaded). However, none of the buttons respond after pairing. Only when I plug it in the USB port does it work.
      What do I need to do to fix this?
      Thanks
        Scavy Global moderator @ebonwinds last edited by
        Hello @ebonwinds
        Known issues with SN30 pro, SF30 pro and SN30 pro + pads. It concerns firmwares of these pads.
        Here are the right firmware to use (tested et approved by beta-testers) :
        Appairing in android mode START + B :
        SN30 Pro -> firmware v1.33
        SN30 Pro + -> firmware v4.01
        SF30 Pro -> firmware v1.33
        Last firmware updates don't work fine. A fix is in progress.
        ebonwinds 2 Replies Last reply Reply Quote 1
        • ebonwinds
          ebonwinds @Scavy last edited by
          @scavy Thanks!
          That got it to work in the menu system, but games are still not responding.
          • ebonwinds
            @scavy never mind. I realized it had to be set to input 1. It's all good. Thanks again.
