    GPD Win 16:9 HELP
    Your recalbox
    gpd win 169 help
    • TheGildedGoo
      TheGildedGoo last edited by
      I have been trying for hours to get Recallbox to switch to Landscape orientation on the EmulationStation menu. I need help. Before anyone says why dont I just use Ubuntu and install on top. I did. I don't like the feel of it.
        Zing Global moderator Translator @TheGildedGoo last edited by
        @TheGildedGoo have you read the documentation?
        https://recalbox.gitbook.io/documentation/tutorials/video/display-configuration
        TheGildedGoo 1 Reply Last reply Reply Quote 0
        • TheGildedGoo
          TheGildedGoo @Zing last edited by
          @Zing the documentation doesn’t cover anything other than the Pi at least from what I can tell and have read. The GPD Win is x64. I dug into the system files through ssh to see if I could modify a config file to adjust the display through there but you can’t modify the file and the Sudo or su function doesn’t exist. I didn’t think to use chmod though to adjust the permissions. 😩
            @TheGildedGoo I think it's really not compatible, check this out:
            https://forum.recalbox.com/topic/22193/problème-d-écran-superposé
