    Manette Générique PS3 - recalbox 7.1.1 sur Rpi4
    7.1.1 générique ps3 recalbox rpi4
    • AdL38
      AdL38 last edited by AdL38
      Bonsoir,
      J'ai acheter cette manette, numéro de Modèle CECHZC2U
      Je suis sur un rpi 4 avec un recalbox 7.1.1
      J'ai essayé de la connecter, mais que cela soit en filaire ou bluetooth, recolbox ne veut rien savoir (j'ai essayé les 3 drivers d'origine de recalbox aussi), voici ce que j'obtiens dans les logs :
      RECALBOX user.info kernel: [ 814.003218] usb 1-1.2: new full-speed USB device number 17 using xhci_hcd
      RECALBOX user.info kernel: [ 814.140600] usb 1-1.2: New USB device found, idVendor=054c, idProduct=0268, bcdDevice= 0.01
      RECALBOX user.info kernel: [ 814.140608] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
      RECALBOX user.info kernel: [ 814.140615] usb 1-1.2: Product: PS3 Controller
      RECALBOX user.err kernel: [ 814.145291] usbhid 1-1.2:1.0: can't add hid device: -32
      RECALBOX user.warn kernel: [ 814.145315] usbhid: probe of 1-1.2:1.0 failed with error -32
      RECALBOX user.info kernel: [ 814.222792] usb 1-1.2: USB disconnect, device number 17
      RECALBOX user.info kernel: [ 814.723230] usb 1-1.2: new full-speed USB device number 18 using xhci_hcd
      RECALBOX user.info kernel: [ 814.861704] usb 1-1.2: New USB device found, idVendor=054c, idProduct=0268, bcdDevice= 5.72
      RECALBOX user.info kernel: [ 814.861712] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
      RECALBOX user.info kernel: [ 814.861718] usb 1-1.2: Product: PS3 Controller
      RECALBOX user.err kernel: [ 814.868791] sony 0003:054C:0268.0007: failed to retrieve feature report 0xf2 with the Sixaxis MAC address
      RECALBOX user.info kernel: [ 814.869093] sony 0003:054C:0268.0007: hiddev96,hidraw0: USB HID v81.11 Joystick [PS3 Controller] on usb-0000:01:00.0-1.2/input0
      RECALBOX user.err kernel: [ 814.869101] sony 0003:054C:0268.0007: failed to claim input
      RECALBOX daemon.info bluetoothd[974]: sixaxis: compatible device connected: PLAYSTATION(R)3 Controller (054C:0268)
      J'ai fait pas mal de recherches mais sans trouver de solution, si quelqu'un a réussi à faire fonctionner ce générique PS3 sur la même configuration, je veux bien savoir comment il a fait.
      En vous remerciant.
      100.5k
