    ZX Spectrum games not launching
    Emulator Arcade/PC/Console
    emulationstatio
    • eldontyrell
      eldontyrell last edited by
      Hello all ! I just installed the latest recalbox version (4.0) and I even updated it when running the distribution. However it seems I cannot run any of the ZX Spectrum games. I get a blank screen and then it goes back to the games list. My games are in .Z80 or .SNA format. Should I place some 48K/128K rom somewhere ? Did some of you experienced the same problem ? Same for Neo Geo but I suspect I could lack a bios file somewhere. Thanks !   Stéphane
        Hello, can you try to disable the rewind option in ES ?
        • eldontyrell
          Ok, I will try it this evening and will keep you updated. Thanks !
          • diwou
            diwou last edited by
            I had the same problem. The entry "zxspectrum.rewind=0" in the "recalbox.conf" worked. Thanks  to rockaddicted!
            • ashmck73
              ashmck73 last edited by
              Thanks - I was having the same issue and that seems to have fixed it.
