    Flydigi Apex (Bluetooth) Controller w/Pi 4
    GamePad/GPIO/USB encoder
    flydigi apex bluetooth wpi
    • misterrasta
      misterrasta last edited by
      Hi!
      Brand new to all this. Just put together my Pi 4 and flashed the latest version of Recalbox.
      I also just got a Flydigi Apex (Android) Bluetooth controller. For the life of me I can’t seem to get it working.
      My wired controller works just fine. And Recalbox knows that there are two controllers connected (my wired and the Apex).
      But no matter what I do none of the Apex’s buttons work and I can’t configure it.
      Anyone successfully using one of these with a Pi 4? Is there something I’m missing?
      Thanks for any help!!!
      misterrasta 1 Reply Last reply Reply Quote 0
      • misterrasta
        misterrasta @misterrasta last edited by
        @misterrasta Got it working. There are three modes (Bluetooth, Android, and PC - the latter 2 using the wireless dongle) and it seems that Android is working just fine for my RPi4.
        In order to get it to work I had to switch to Android mode. THEN power off and on the controller, press and hold the Pair button.
        The indicator light will start rapidly flashing. Unplug the wireless dongle and re-plug it in with the controller positioned less than 20cm from the dongle. The indicator light will them remain solid and you can configure the controller in Recalbox. Good luck!
