    Black and white Tv's
    Themes & Interface
    white tvs
    • ajbmorais
      ajbmorais last edited by
      Hi, is there a way to get the sinclair emulator to run in black and white mode?
      I've setup recalbox x86 in a netbook and want to run spectrum games on monochrome.
      Thanks
        Zing Global moderator Translator @ajbmorais last edited by
        @ajbmorais I think the best option is to use shaders, there are several that come in Recalbox and you can test it, just go to the main menu, game options, shaders.
        If you want, you can download new Shaders from the internet, I believe the "grayAverage" shader is what you are looking for:
        https://github.com/aybe/RetroArch-shaders
        See if this helps:
        • https://youtu.be/_R0yvMB5zIk?t=277
        • https://recalbox.gitbook.io/documentation/v/francais/tutoriels/jeux/generalite/configuration-des-shaders
