    Solved Recalbox 7.1.1 - Whole system poor performance
    reload7.1.1 performance slowdownhiccup
    2706
    • darkanezi
      darkanezi last edited by
      Hi all!
      I recently updated my system to Reload 7.1.1 and I’m having issues with performance. It is perceptive the system struggling right on the dashboard’s game transition that seems to be stuttering, not smoothly sliding. Then all emulators are having the same symptoms no matter what game, it’s image is stuttering and slow, and the sound is also cracking as if the CPU or the GPU didn’t have enough power to process that (happened a lot with my Raspberry Pi 3+ trying to run PSP, it just didn’t have enough processing power to run that smoothly). This only started after I installed the last update 7.1.1. My hardware is a Raspberry Pi4 8GB RAM with a 500gb SSD drive (system and games in it) in a Nespi4 Case.
      Maybe that has something to do with GPU tweaking or even a new feature that needs to be reconfigured?
      Any help with that is much appreciated! 🙂
      • olivierdroid92
        Hi
        Let's try to find what and where is the concern
        Can you please tel me on which system you have an issue.
        On witch game?
        darkanezi 1 Reply Last reply Reply Quote 0
        • darkanezi
          darkanezi @olivierdroid92 last edited by darkanezi
          Hi @olivierdroid92, thanks for your reply! So, any game that I have tested so far of all emulators are having this issue except Nintendo64 (which is weird as that would be precisely the one I would expect this behavior). NeoBF, Mame, Mega Drive, NeoGeo, PSP, DreamCast, PSX, all of them are presenting the same symptoms, which leads me to think that this is a system issue and not isolated. My impression is that the emulation station have a speed control and that was tuned down, as if everything was slightly slower, in slow motion...
          Thank you!
          olivierdroid92 toniosj 2 Replies Last reply Reply Quote 0
          • olivierdroid92
            olivierdroid92 Global moderator @darkanezi last edited by
            @darkanezi
            Image 7.1.1
            Rapsberry Pi4 at 720p
            All my games are running fullspeed, at 60FPS with overlays.
            May be can you can try with an other ROM support : either micoSD card, USB Stick, USB hardsik
            • toniosj
              toniosj Spanish moderator @darkanezi last edited by
              @darkanezi Are you using shaders?
              olivierdroid92 darkanezi 2 Replies Last reply Reply Quote 0
              • olivierdroid92
                olivierdroid92 Global moderator @toniosj last edited by
                @toniosj
                No i do not use any shader.
                I do not have enable 'pixel perfect'
                I only used 'my overlay' pack from SS with some adjustments.
                https://forum.recalbox.com/topic/22321/recalbox-7-x-overlays-complets
                • darkanezi
                  @olivierdroid92 Yes, mine was running just fine before the update 7.1.1... after updating things started to behave like this...
                  • darkanezi
                    darkanezi @toniosj last edited by
                    Hi @toniosj, honestly I don’t know, is there any file that I can check this config?
                    Thank you!
                    • darkanezi
                      Ok, I backed up my system and fresh flashed my SSD with Reload 7.1.1... didn’t change any config or transferred any game, just ran the built in games, same exactly issue, slow and stuttering...
                      Then I re-flashed again with version Reload 7.0.1 and magically everything was back working as it should. If I was to guess the issue I would say it is something related to the SSD... anyway, I will keep this version for some time until we figure what is going on with version 7.1.1...
                      Thank you!
                      • olivierdroid92
                        @acris
                        ce sujet est CLOS
                        serait il possible de le mettre SOLVED, CLOSED
