    Themes bug with 7.0.1 and 7.1.1 release.
    themes 7.0.1 7.1.1 release
    • Space81
      Space81 last edited by
      Hi guys, as you know the themes no longer work with versions 7.0.1 and not even with 7.1.1, I tried to select the theme that I have always loved Next Pixel (4:3 version), but I keep having problems, screen and black and white texts.
      My Config : RPI 3B+ RB 7.1.1
      Thank you for your great work.
        Scavy Global moderator @Space81 last edited by
        @Space81 hi, well, the next-pixel theme works fine on my 7.1.0 then 7.1.1 version using my GPiCase.
        Are you sure it's well installed ?
        Your theme is installed in the share/theme/ folder correctly ?
        Take care about the two same named folder : share/theme/nextpixel[...]/nextpixel[...]/
        it's a common problem.
        Space81 1 Reply Last reply Reply Quote 1
        • Space81
          Space81 @Scavy last edited by Space81
          Hi, my theme is installed correctly in the share / theme / folder
          I usually unpacked the zip in the “share / theme /“ folder and did nothing else, however I'll check as soon as possible.
          Very thanks @Scavy
            Scavy Global moderator @Space81 last edited by Scavy
            @Space81 a picture is more usefull
            ---> what is good :
            ---> what is wrong :
            Check your path.
            Take care, it's my GPiCase pack (small crt), not the 480p, 720p or 1080p pack
            • Space81
              @Scavy very very thanks ! You were right, that was the mistake. 🙂
