    Theme Recalbox-next - Best setting with Skraper
    Themes & Interface
    recalbox-next setting skraper theme
    • olivierdroid92
      When using https://www.skraper.net/ skraper external scrap,
      Should be good to optimzed picture size
      Defaut size is 745 x 745 when nothing is provided.
      Exemple :
      Whith nothing
      If you are running a
      GPI CASE you can go with 170 x 170 image size
      On 1080 p screen : Pi4, XU4 or PC
      With small image like
      Go with 460 x 460
      With Big image
      keep with nothing and will fit for
