    recalbox on two TVs with raspberry pi 4?!
    Your recalbox
    recalbox tvs
    • neo207
      neo207 last edited by
      hello. can i plug in two hdmi into the rpi4 and have the same image on two televisions? i cannot test right now, because i don't have an hdmi adapter for the second hdmi-port.
      but would be interesting to know because at the moment, i have an hdmi splitter on one hdmi port - works well but if i can abandon the splitter, i would have less cables and devices around.
      • phimjohn
        phimjohn last edited by
        Would like to know this as well. Would be great to run it in a back-to-back arcade 1up for a realistic arcade experience.
        • MaddisonWells
          MaddisonWells last edited by
          As far as I know, you can connect two TVs. You just need to make a separate setting for each of them. I made the same setting for my project, and I did it.
          MaddisonWells 1 Reply Last reply Reply Quote 0
          • MaddisonWells
            MaddisonWells @MaddisonWells last edited by
            @MaddisonWells said in recalbox on two TVs with raspberry pi 4?!:
            As far as I know, you can connect two TVs. You just need to make a separate setting for each of them. I made the same setting for my project IEEE format, and I did it.
            If you need help, write to me in PM.
