    [SOLVED] Open WiFi connection for 4.0 ?
    [solved] open wifi connection 4.0
    5498
    • styletwo-wan
      styletwo-wan last edited by
      I really need to connect to open WiFi (i.e. no password).  How can I do this for recalbox 4.0 ?  Thank you very much indeed !
      • styletwo-wan
        I found the solution.  Thx.
        PUCH84 1 Reply Last reply Reply Quote 0
        • bulletent
          bulletent last edited by
          How did you solve this issue I am having same problem.
          Thks
          • PUCH84
            PUCH84 @styletwo-wan last edited by
            @styletwo-wan please any solution?
            I have been researching that I have to edit the "wpa_supplicant.conf" file, "
            adding: "auth_alg=OPEN " but I always get the "no write permission" warning when I try to edit with nano. There are other way?
            Thanks in advanced.
            gkralicek2 1 Reply Last reply Reply Quote 0
            • gkralicek2
              gkralicek2 @PUCH84 last edited by gkralicek2
              @PUCH84 First, i'd advise you not to post in a topic that has been marked as "solved" otherwise there is very little chance that you'll catch people attention.
              Create your own topic ! :=))
              Then, concerning the fact you cannot write your file, the reason is that the root system partition is write protected and you need to allow read/write operation prior to modification using nano with the command :
              mount -o remount,rw /
              Your wpa_supplicant should look like this for open connection :
              ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=root
              network={
              ssid="name_of_your_ssid"
              key_mgmt=NONE
              auth_alg=OPEN
              scan_ssid=1
              priority=100
              • PUCH84
                PUCH84 @gkralicek2 last edited by
                @gkralicek2 Thanks so much, but II am still getting the error message after modify the file as you said. The file to edit is wpa_supplicant.config in /etc/ directory or anothe one?
                • gkralicek2
                  @PUCH84 you have to modify the file named wpa_supplicant.conf and located in etc/wpa_supplicant/ folder (not the one in /etc)
                  • PUCH84
                    @gkralicek2 Thanks so much! Finally it works!
                    • gkralicek2
                      @PUCH84 That's perfect then ! :=)
