    Mame Emulator
    Emulator Arcade/PC/Console
    mame
    • kalogerisan
      kalogerisan last edited by
      Hello guys i installed Recalbox on my Pi 2 and i have installed 0.78 roms for mame. I have downloaded a full set and installed roms on Mame folder but none of them work. I figured i had a wrong set and downloaded another .78 set and just to be perfectly sure they are compatible i run them through clrmamepro. Again no games run. I click them, screen goes black for 3 seconds and i'm back to game selection screen. Any ideas would be appreciated since i really want to make it work. Thanks in advance.
      • aameiel
        aameiel last edited by
        Did u add a bios file with it ? Thats how i got mine to work.
          voljega Banned last edited by
          You don't need clrmamepro if you have the right romset. For most games you need the related bios zip file in the same folder (mame rom folder) for instance neogeo games need neogeo.zip from the full romset to work
