    question about a theme (and maybe help)
    Themes & Interface
    themes theme recalbox win10
    • RealAzyria
      RealAzyria last edited by
      i wanted to ask a question.. i'm using emulationstation for windows 10.. i use it when i stream on twitch.. anyways has anyone gotten the [Recalbox 6.1+][Snap Videos][Custom mix] Next Pixel theme to work on the windows 10 version? its the only theme from my recalbox that doesn't work
        Zing Global moderator Translator @RealAzyria last edited by
        @RealAzyria if you are using emulatiostation on Windows, it is nothing related to Recalbox, therefore, you are escaping the purpose of the forum, and will not be supported. I recommend that you contact the creator of the theme in private if you want this kind of support, maybe he can help you.
        • mYSt
          mYSt Theme moderator last edited by
          Hello!
          Next Pixel theme is only compatible with Recalbox since its uses its own emulationstation fork
