    Problema con Natomiswave
    Emulador Arcade/PC/Consolas
    problema con natomiswave
    • Vaguito
      Vaguito last edited by Vaguito
      Estimados, he intentado arreglar un problema que tengo con natomiswave, lamentablemente no he encontrado solución, el mismo problema lo encontre con Naomi y tengo entendido que ocupan hasta la misma Bios segun lo que encontre. los logs me indican lo siguiente:
      es_log.txt
      Natomiswave
      [2020/07/06 04:07:29.776] (INFO ) : Controllers config :
      [2020/07/06 04:07:29.785] (INFO ) : 	python /usr/lib/python2.7/site-packages/configgen/emulatorlauncher.pyc  -system atomiswave -rom /recalbox/share/roms/atomiswave/Metal\ Slug\ 6.bin -emulator default -core default -ratio auto
      [2020/07/06 04:07:32.272] (WARN!) : ...launch terminated with nonzero exit code 256!
      [2020/07/06 04:07:32.272] (INFO ) : Creating surface...
      [2020/07/06 04:07:32.393] (INFO ) : Created window successfully.
      [2020/07/06 04:07:32.791] (INFO ) : SDL AUDIO Initialized
      [2020/07/06 04:07:32.791] (INFO ) : playing
      con Naomi
      [2020/07/06 04:13:27.168] (INFO ) : Controllers config :
      [2020/07/06 04:13:27.187] (INFO ) : 	python /usr/lib/python2.7/site-packages/configgen/emulatorlauncher.pyc  -system naomi -rom /recalbox/share/roms/naomi/Capcom\ vs.\ SNK\ 2\ Millionaire\ Fighting\ 2001.bin -emulator default -core default -ratio auto
      [2020/07/06 04:13:29.245] (WARN!) : ...launch terminated with nonzero exit code 256!
      [2020/07/06 04:13:29.245] (INFO ) : Creating surface...
      [2020/07/06 04:13:29.475] (INFO ) : Created window successfully.
      [2020/07/06 04:13:31.363] (INFO ) : SDL AUDIO Initialized
      [2020/07/06 04:13:31.363] (INFO ) : playing
      Muchas gracias ojala me puedan ayudar
        Zing Global moderator Translator @Vaguito last edited by
        @Vaguito Lee este enlace:
        https://forum.recalbox.com/topic/18865/a-lire-naomi-atomiswave
