    How do i change EmulationStation Sounds/images??
    soundsimages
    • psy-orzaez-mushroomadelic
      psy-orzaez-mushroomadelic last edited by
      I want to change the sounds that pay when you select an emulator and the background images, how can i achieve that? I have connected the SD of the Raspberry Pi, and i cannot find the location where the images/sounds are stored, how can i change them?
      • darkbrokenheartz
        darkbrokenheartz last edited by
        Those files would be located in the /root/.emulationstation/themes/ Directory inside each theme so for simplelight in /root/.emulationstation/themes/simplelight/snes/art /root/.emulationstation/themes/simplelight/snes/sounds you should look up some guides about how people make custom themes for retropie im sure that would be step for step but you can just manually edit the files in those directories. dont change filenames around though.
          Thanks! Now ive successfully created my theme 🙂 thanks!! i have another question on the general forum though, maybe you can help me to answer it, please?
