    FBA Libretro
    fba libretro
    • scrummel
      scrummel last edited by
      So, I dumped the NeoGeo.zip into my FBA Libretro folder via SSH. I noticed the folder is available to select from the menu but this is obviously the bios. I also dumped a few versions of SFIII 3rd Strike in the same way, but they are unplayable. Any suggestions?
      • kenwong
        kenwong last edited by
        your zip file must be the "right" one. did you check md5?
        101.4k
