    Need help for Mame / FBA_Libretro / NeoGeo Arcade
    xbox360 control lag fba fbalibretro
    6995
    • tr1plx
      tr1plx last edited by
      Hi recalboxer, I'm following this how-to: https://github.com/recalbox/recalbox-os/wiki/Easy-Arcade-on-Recalbox-(EN) It says:
      • Now check the BestArcade4Recalbox document and locate which system is the best for the game you want to play :
        • if it's in the mame tab, copy the game rom file from your complete 0.78 romset to the mame roms folders
        • if it's in the fba_libretro tab, copy the game from your complete 0.167 romset (or 0.161 or any other close to that) into the fba_libretro rom folders
        • if it's in the 'not found or not working' tab, well guess what ?
      Ok. I have complete Romset 0.78 and 0.167 - I did a rebuild with clrmamepro and the DAT-Files from the corresponding ROM-Folders BUT I haven't figured out how to seperate NEOGEO Roms or the ROMs better work in MAME or FBA_Libretro. Is where a way to seperate them automatically with a tool or have I to sort and upload them manually with the list ?
        voljega Banned last edited by
        Yeah no sadly there is no tool for the moment, I wrote one at home but can't share it for the moment (it's not usable by someone other than a java developper). In fact I used that one to build the romset used for testing all the games in the spreadsheet   So you have to do it by hand... I know ! it's boring ! Sooooorry
        • tr1plx
          ok thanks. Sadly that's not the answer I hoped for... 🙂 Do you know how to seperate the NEOGEO ? There's no extra tab in the list ? Maybe theres a clrmamepro DAT File for the 0.167 ROM List to rebuild from ?
            Well every game containing SNK in manufacturer column will be a neogeo game, but there are some others too... You could use ClrMamePro I think but personnaly I hate the thing and never use it
              And then there's that : https://en.m.wikipedia.org/wiki/List_of_Neo_Geo_games
              • tr1plx
                ClrMamePro is a good working tool - for me it worked fine after serveral try & errors 🙂 But no DAT File no Rebuild 🙂 So I have to check out another solution - do you know If there's a way to sort an excel-file to the background color ?
                  Background color will only tell you if the game is working or not ?   Yeah I think you can do it in Excel in Google Spreadsheet I don't know
                  • tr1plx
                    ok now I'm having a simple and working solution. 1. Save the BestArcade4Recalbox Document as an Excel-File (.xlsx) 2. in Excel go to Tab Mame (0,78) - click on "Data" and sort by color "green" - these are the ones I'm interessted in for this tab. 3. Create a new Column H with formula: ="G:\ROMs\Mame\MAME 0.78"&C2&".zip" and copy this Column in a blank TXT-File called 078_green.txt - You should have exactly 370 FileEntrys of green and working ROMs for Mame. G:\ROMs\Mame\MAME 0.78\ is there my complete 0.78 ROM-Set is stored - you have to change this to your corresponding path 4. Create a Textfile called copy078.bat and edit:
                    @echo off & setlocal for /f "usebackq delims=" %%i in ("G:\ROMs\Mame\078_green.txt") do copy "%%i" "G:\ROMs\Mame\green078" >nul
                    5. Open a commandline Tab, cd into the dir of your BAT and execute. You get every 370 game in your DEST-Folder which you can transfer to your recalbox (/recalbox/share/roms/mame) 🙂
                      Cool and simple solution ! Don't forget the bios 😉
                      • tr1plx
                        Hey Voljega, on github https://github.com/recalbox/recalbox-os/wiki/Advanced-Arcade-on-Recalbox-(EN) you wrote:
                        <h4>piFBA</h4> Recalbox (all versions)
                        • piFBA is the most powerful arcade emulator on recalbox.
                        • It uses the FBA romset version : FBA 0.2.96.71 which is based on MAME 0.114 (April 2007)
                          • Size : 3.62GB
                          • Romsets emulated : 684 (no clones in this)
                        • roms folder : fba
                        From the 684 romset in 0.2.96.71 are not all working, right ? Only those which are mentioned in the list ? So there's no need to copy them all over to recalbox ?
                          Yeah there's not need to keep all the roms but the list is for fba_libretro wich uses a more recent romset not pifba (I should test that one when I find the time)   Pi-fba is supposed to be more optimized so I think you can try all games if the list in green yellow and orange     Actually more games should worh with pifba, with fba_libretro many roms were lagging so i removed them from the list
