    Gamecube and Wii - distinct Dolphin configuration files ?
    GamePad/GPIO/USB encoder
    gamecube wii distinct dolphin
    • AxelR
      AxelR last edited by
      Hello !
      In many cases we have to use the gamecube.configfile=dummy or wii.configfile=dummy flags in recalbox.conf, to be able to adapt the Dolphin controllers configuration and make this configuration persistent.
      Would be great if recalbox/configgen could handle distinct configurations for controllers when launching Wii Games vs when launching Gamecube Games.
      Even though the Dolphin emulator relies on 2 separate configuration files for Wiimotes and for GC controllers (WiimoteNew.ini ans GCPadNew.ini), both are loaded when launching a game. As a result, some Wii games are confused if both GC controllers AND Wiimotes are configured in Dolphin (for example one pad will control 2 players. One as a Wiimote and the other as a GC controller).
      Ideally, for each emulator (GC or WII) we should be able to point to a real configuration file in recalbox.conf, not a dummy name, and that configuration file would be the only one used by Dolphin.
      Hope that makes sense...
      Thanks for your amazing work on Recalbox ! The 6.2 release seems amazing (again !)
      100.7k
