    Controller won't work in Emulators
    GamePad/GPIO/USB encoder
    won039t
    • anima
      anima last edited by
      dear all, I just installed recalbox and used a USB keyboard in order to get to the configuration to configure my Logitech F310 controller.. which worked quite well.. but somehow I can't use the controller in some emulators.. however controlling UI of recalbox itself works quite well with the F310.. I have no idea what to do, hence in some cases it works.. like in Mario 64 (N64) or with Street Fighter Turbo (SNES) any help is much appreciated thx and best regards
      • nosfay
        nosfay last edited by
        Hi, Unfortunately, you have to configure N64 controller manually : https://github.com/recalbox/recalbox-os/wiki/Configure-N64-controllers-(EN)   Can you play correctly other SNES games ? If yes, i suggest to change snes core emulator in recalbox.conf : https://github.com/recalbox/recalbox-os/wiki/recalbox.conf-(EN)
        • anima
          hi, thx for advice but I solved it myself.. I was a little too fast with configuring and thus had a second controller configured at the time.. didn't mentioned tho because I thought it wouldn't matter.. as a fact, it did.. I unplugged both controller and restarted the system.. plugged in my F310 (and only this controller..) and did the whole configure part again.. now everything works just fine and it's awesome btw 🙂 ... way faster than retropie, if I'm allowed to say here^^ best regards
