    PSX Recalbox
    Your recalbox
    psx
    6
    7
    6096
    • duglim
      duglim last edited by
      Hi, after 3 huge cabs I decited to start a small recalbox project: A PSX retro station. I stripped all the stuff off my old PSX and replaced it with a Raspberry Pi 2 and additional stuff. PSX Recalbox All in all, I build it this way: - Raspberry Pi 2 - 32 GB mSD - 1 TB HDD - 3A power supply - USB Wifi - 2x USB wireless Gamepad (CSL PS3/PC Gamepads with propriatary USB dongles, not Bluetooth) - HDMI extension cable Hardware mods: - The power supply was build into the PSX and connected to the original PSX power plug. - The connection from Pi power supply to Pi was connected to the PSX power switch, so you can turn it on and off using the original switch. - A wired the PSX power LED to the GPIO connectors 3.3V pins, so the power LED is working. Software mods: - Share partition changed to external USB HDD - USB voltage raised to 1.2V - SNES core changed to SNES9x_next - NeoGeo core changed to fba_libretro - Pi overclocked to 1050 MHz - Added Retroarch hotkeys for Disc change and tray open/close - Set PSX as default system to show after boot - Configured systems: - PSX with full PAL set, 1.200+ games - SNES - NES - GB/GBC - Genesis - MasterSystem - GameGear - NeoGeo - TurboGrafx-16 Everything is working really well. Scraping all systems was a pain, but now all systems are scraped to +90%, only PSX is stuck around 70%, since many PAL games are not in the gamesDB I assume. I will gift this nice thing to a friend in a few weeks, hope he likes it. 🙂 Thx for this great Recalbox piece of software and all the helpful information in this board! I will post additional pics later. 😉 Greetings, Duglim
        voljega Banned last edited by
        That's a nice gift !!
        • duglim
          Picture of the finished project 🙂 The charger next to the PSX is for the two controllers.   Greetings, Duglim
          • neophyte
            neophyte last edited by
            Nice Work! I´m building the same, but I have some problems with the PSX Power Unit. Do you have a picture from the back of it, so I can see how you got the Power switch to work? I don´t know where to solder the wires for the switch to work   thanks
            • biloon
              biloon last edited by
              Salut à tous savez comment brancher sur le switch ON / OFF de la carte d'alimentation de la PSX  ?
              • god007
                god007 last edited by
                Hello Dan, Great Job. I will try to made a similar thing. Thanks to have share with us that project Hello BilooN, Je ne sais pas si tu as pu résoudre ton problème mais je viens de récupérer une PSX pour faire le même type de projet, naturellement on ne peut pas utiliser la power de la PSX pour remplacer celle du RPI car j'ai noté en tension de sortie soit 3,4V ou 7,5V et je n'y connais pas grand chose pour modifier la tension par un changement de composant et avoir les + ou - 5V attendu. Pour le bouton Power si tu veux le remettre sur le GPIO du RPI, il faut dessouder tout le reste des composants et souder 2 fils sur le CI au niveau du bouton. Tu peux laisser le bouton reset cela évite que le bouton de la PS tombe et a voir pourquoi pas pour le brancher sur le GPIO aussi si besoin. Pour la LED, visiblement c'est possible aussi, je vais regarder aussi pour faire comme Dan et avoir la led Allumée et alimentée par le GPIO. Je ne suis qu'au début, je fais la partie facile (démontage et peinture), j'ai mis en noir mat ma PSX comme elle est à coté de ma PS3 et PS4. je garde bien sur ma 1ere PSX que j'ai acheté à sa sortie en état d'origine dans mon placard. A+
                • heden
                  heden last edited by
                  je monte moi aussi une recalbox dans une ps1 (voir le forum) j'ai vu sur un blog anglais que sur certain modele d'alim de ps1 il fallait juste changer 2 resistances mais il faut un module pour la tension specifique donc faisable mais compliqué a avoir la bonne alim . moi j'ai demonté mon boitier fourni avec le pi3 et mis dans la ps1 mon topic : http://blog.recalbox.com/forums/topic/recalbox-dans-ps1/
                  Ma RetroStation
                  https://forum.recalbox.com/topic/3184/recalbox-dans-ps1
