    Can i install Transmission inside recalbox ?
    transmission
    • n13oss
      n13oss last edited by
      I found this tutorial pimylifeup.com/raspberry-pi-torrentbox/ And it will be great if my recalbox can load bittorrent too. Can i use this tutorial on recalbox ? because i use putty to login ssh but i cant use command to install like sudo apt-get update How can i install transmission ?
        Hi, nope you can't. Recalbox is based on a linux build from scratch and thinked as a firmware. So it doesn't include any package manager (apt-get). If you want to include transmission to your recalbox, you need to add it from scratch and build your own recalbox. More informations here : https://github.com/recalbox/recalbox-os/wiki/Compilation-&-Modifications-(EN)
        • n13oss
          wow , Thank you very much for your reply.
