    Username for Webinterface
    username webinterface
    • mindstormfront
      mindstormfront last edited by
      Hi,
      I set a password for the webinterface. Unfortunately I was not able to login to the webinterface afterwards.
      Could someone provide me with the user I should use for the webinterface ?
      If it would not work with the correct user neither, how can I disable the password for the webinterface ?
      BR Mindstormfront
      mindstormfront 1 Reply Last reply Reply Quote 0
      • mindstormfront
        mindstormfront @mindstormfront last edited by mindstormfront
        I already tested: webmanger, root, recalroot as username with the password I set.
