    Unsolved Is 6.1.1 unstable for PC ?
    Emulator Arcade/PC/Console
    6.1.1 unstable
    • yarg
      yarg last edited by
      Hi, I recently wanted to try the recalbox project and installed it on an old tower of mine in order to make use of it. It is equipped with a 2.8GHz G6950 Pentium and no GPU, so while I didn't have much expectations, I am clearly disappointed by the fact that everything from the menu to the games runs very poorly, at maximum 3 fps (even something like the NES !).
      I am kinda in denial with thinking that my pc is just not enough, and while I never planned to go any further than the N64 I am pretty sure such configuration can do way better than that.
      To support that, while trying to find a similar issue on the forums i've read that the last recalbox isn't really well-optimised for PC.
      So, is recalbox really the culprit with very bad resource management and if yes, where could I find the image of an older, better-suited version, or if no, what would you recommend in order to have something that runs smoothly ?
      Thank you in advance for any helpful reply
      • jaroshki
        jaroshki last edited by
        Hi
        have you installed the 32bit version of Recalbox?
        I am running Recalbox 6.1.1 on my 13 years old Pentium3 and it is working flawlessely.
        Legion C530, i5-8400 CPU, 64-Bit, GeForce GTX 1060 6GB, Recalbox 6.1.1
