    Super Smash Bros N64
    mario smash bros
    • Ewilana
      Ewilana last edited by Ewilana
      Hello,
      I've installed various ROMs for Super Smash Bros (it is partly to play this game that I bought a Raspberry) but it is lagging and impossible to play... Does anyone face the same issue?
      Thanks
      • sn3k1ng
        sn3k1ng last edited by
        @Ewilana said in Super Smash Bros N64:
        Try to change the emulator or change the core...
        I use to have the same issue but changing the option CORE to RICE solved
        • Cédric Hammer
          Cédric Hammer last edited by
          Also check your RPI temp (you can check that in the webmanager interface), as it may throttle if temp is too high ...
          Solutions then vary : add a ventirad, change your case, etc.
          RPI3b / Recalbox 6.1.1-DragonBlaze / 2x 8BitDo SF30Pro
