    Probleme jeux MGT SAM COUPE
    mgt sam coupe
    • ERAGON622
      ERAGON622 last edited by
      Bonjour a tous
      Je souhaiterais comment lance t'on un jeux MGT SAM COUPE
      Merci a tous
        Bonjour @ERAGON622
        sam coupé est un ordinosaure il faut obligatoirement un clavier pour jouer.
        edit : aucune idée si les touches sont ok
        KEYBOARD INPUT
        The default SAM keyboard mode allows letters, digits and symbols to be typed
        as normal on your keyboard, with SimCoupe automatically converting them to the
        appropriate SAM key sequence. There's also a Spectrum mapping mode to use when
        running Spectrum software, and a raw mode to disable the mappings.
        The SAM has a keypad of function keys from F0 to F9 located on the right-side
        of the keyboard. For similar key positions in SimCoupe, the SAM keypad is
        mapped to the numeric keypad on your keyboard. You'll need to have Numlock
        enabled for these keys to be recognised. Don't forget that when SAM software
        refers to function keys, you must use the numeric keypad instead!
        F1 to F12 keys on your keyboard are used for emulator functions, with the
        default mappings shown below. Under OS X, keys F9 to F12 are used by Expose
        and Dashboard, so you'll need to hold the Command key in addition to the
        combinations below to access them.
                     F1 = Open disk 1
               Shift-F1 = Eject disk 1
                Ctrl-F1 = Save disk 1
                 Alt-F1 = New disk 1
                     F2 = Open disk 2
               Shift-F2 = Eject disk 2
                Ctrl-F2 = Save disk 2
                 Alt-F2 = New disk 2
                     F3 = Tape browser
                     F4 = Import data
               Shift-F4 = Export data
                 Alt-F4 = Exit application
                     F5 = Toggle 5:4 display
                     F6 = Toggle display smoothing
                     F7 = Toggle CRT scanlines
               Shift-F7 = Toggle hi-res scanlines
                     F8 = Toggle full-screen
                     F9 = Deb****r
               Shift-F9 = Save screenshot
                    F10 = Options
                    F11 = NMI Button
                    F12 = Reset button
               Ctrl-F12 = Exit application
              PrintScrn = Save SAM screenshot in PNG format
                  Pause = Pause emulation
            Scroll Lock = Pause emulation
             Ctrl-Break = Reset
          Ctrl-Keypad * = Reset
          Ctrl-Keypad - = Normal emulation speed
               Keypad - = Reduce emulation speed
               Keypad + = Increase emulation speed
               Keypad * = Turbo speed
        Turbo speed disables the frame sync and sound, and limits the display to just
        5 frames per second. This usually gives a big speed boost, which is useful for
        zooming through slow sections in games and demos, etc.
        SAM shift modifier keys and special symbols are mapped as follows:
                 Insert = Inv
              Left-Ctrl = Symbol
             Right-Ctrl = Cntrl
               Left-Alt = Cntrl (if enabled)
              Right-Alt = Edit  (if enabled)
               Menu Key = Edit
          ` (backtick)  = (c)
          . (on keypad) = (c)
            § (section) = #
        The following additional combinations are also provided for convenience, since
        they map common keys to the equivalent function on the SAM:
             Native key   SAM key
                 Delete = Shift-Delete
                Numlock = Symbol-Edit  (toggles SAM BASIC keypad mode)
                   Home = Cntrl-Left
                    End = Cntrl-Right
                Page Up = F4
              Page Down = F1
        • ERAGON622
          merci beaucoup pour l'info je vais tester tous ca
