    How to install a wifi driver on PC 64-bits?
    wifi driver 64-bits
    • DarkFulgore
      DarkFulgore last edited by
      Hey guys, I'm having trouble connecting to my wifi with the Recalbox PC 64-bits. I'm using it on a HP DV-6, but it doesn't recognize my wifi board.
      Tried using the USB dongle I use on my Rasp 2 and it doesn't work either.
      Did a quick check on the terminal and the OS shows my wifi board, but it doesn't show my wlan0 and I have no access to a RJ45. How can I solve this? Since the apt-get isn't available either. 😞
      • Dr.Methyl
        Dr.Methyl last edited by
        Are you sure you have wifi driver for linux ?
        • iosman987
          iosman987 last edited by
          Check youtube video, I had already seen it, but for screens i use scraper from Recalbox 6.1.1 directly, so, the same is not possible ?
          iosman987 1 Reply Last reply Reply Quote 0
          • iosman987
            iosman987 @iosman987 last edited by
            @iosman987 said in How to install a wifi driver on PC 64-bits?:
            thanks my issue has been fixed.
