    GiPi Case dragonblaze 6.1 to 6.1.1 upgrade. Arcade section missing on front end
    gipi case dragonblaze 6.1 6.1.1
    • Mammer90
      Mammer90 last edited by
      Using a retroflag Gpi Case with a custom image running dragonblaze 6.1.1. All was fine and it displayed 40 systems including an ARCADE (MAME) section on the front end GUI. Upon upgrading and restarting the ARCADE section is no longer an option on the front end. Checked scraper and systems went from 40 to 39 and arcade does not appear as a system to scrape. I checked the SD card contents from another computer via WiFi and the arcade folder and all the roms are still present.
      Anyone know how to get the ARCADE section to show up again so I can play the MAME roms? I don't want to have to re-image the card again to downgrade. Any help is appreciated. Thank you.
