    [Problem] - Controller SELECT/COIN issue adding a P2 controller
    GamePad/GPIO/USB encoder
    config select two players
    • luca-enei
      luca-enei last edited by
      Hi all, I hope to explain my problem as clear as I can... My english sucks! 😛 I'm using two controllers:
      • Gasiaco wireless PS3 controller (Player 1)
      • SNES usb controller (Player 2)
      When I plug the Player1 controller everything is working fine (hotkeys too), but when I plug the second controller, for example, the "select" button is working on the second controller only, so I can add credits on FBA or MAME from the second controller only. In the emulator configuration I think everything it's ok:
      • credit P1 ---> 5 or retropad 1
      • credit P2 ---> 6 or retropad 2
      This is the same on any other emulators, when I'm using 2 controller, the "select" button works on the second controller only. Does anyone can help me to solve this? Thank you in advace
      • chris-handschuh
        chris-handschuh last edited by
        i have the same prblem with x360 and ps3 controller cmbo
        • luca-enei
          I know, I tried also with a x360 wireless controller and its dongle, same issue
          • luca-enei
            does may be this the solution? "In FBA and Mame, press Select to add a credit. In Mame, if your Hotkey is Select, you will have to quit with R1 + Start (in order to have select as coin)" I paste it from the manual... I'm using a ps3 compatibile controller (gasiaco), so should I have to modify exit button on retroarchcustom.cfg or simply configure another hotkey in emulationstation?
