    Solved GPiCase : SnesPi black screen with Yoshi's Island 2
    Emulator Arcade/PC/Console
    gpicase snespi yoshis island
    • Maldorhan
      Maldorhan last edited by
      Hi,
      Can anyone confirm that Yoshi's Island 2 doesnt work on GPiCase using the new default Snes emulator SnesPi? (Yoshi's Island 1 runs very well).
      It works when using snes9x but it's obviously very slow and unplayable, any tricks to make it work with SnesPi ?
      Thanks a lot guys!
      RPi0W / Retroflag GPi CASE
      RPi3B+ / Retroflag SUPERPi CASE-J
      Retroflag NESPi CASE v1
      • cissou
        cissou last edited by
        SnesPi doesn't emulate superFX2 microchip
        Dell 3020M + X360 sans fil
        Bartop Modulaire : Rpi3
        • Maldorhan
          @cissou said in GPiCase : SnesPi black screen with Yoshi's Island 2:
          superFX2
          Ok thanks for your answer, is there a known trick, rom patch or anything else to make it work on SnesPi?
          Also do you know if SnesPi plans to add SuperFX2 support later?
          Thanks a lot!
          • cissou
            I think Snespi is a dead emulator, so there will be no new feature,
            I hope that snes9x will improve enough to be usable on the pi0
            • Maldorhan
              Maldorhan last edited by Maldorhan
              Oh 😞 ok thanks a lot, I've tried Yoshi's Island 2 (edit 2 of course) on snes9x on the GPiCase and it is indeed unplayable, video and audio both very slow...
