    LIRC kernel mod
    lirc kernel mod
    • chris-handschuh
      chris-handschuh last edited by
      hi, first my sytem deteils: Raspberry PI2 with Recalbox 3.3.0 beta 17 I have setup my infra red controll by this tutorial https://github.com/recalbox/recalbox-os/wiki/Infra-red-remote-control-on-the-Recalbox-(EN) but i have a problem with the lirc kernel modul for the gpio port i uncomment the line dtoverlay=lirc-rpi inside the config.txt but the modul don't load and work lsmod will not display the modul on my second sd card i have openelec and my remote will work   what i can do to get this work   regards
        Hello, about lirc in recalbox beta17, some files were forgotten to be added. So you must wait a new build to see this feature ok.
        • chris-handschuh
          hmm damm, when can i expect with the 4.0.0 release ??
          • chris-handschuh
            ok, i found a solution to get this work i have add all binirys are found in openelec i have packed it and uploaded copy the files and add chmod 755 to all files insert bin and sbin now use the tutorial and have fun https://github.com/recalbox/recalbox-os/wiki/Infra-red-remote-control-on-the-Recalbox-(EN) regards xheen908
